GCX midi connection with GSP1101
kbryant
Post by kbryant » Mon Jan 23, 2017 10:22 am
will connecting my Digitech GSP1101 midi out to my GCX controller in jack cause any damage? can not find midi jack pinout info for GSP 1101
bettsaj
Re: GCX midi connection with GSP1101
Post by bettsaj » Mon Jan 23, 2017 10:33 am
If you connect the midi thru of the GCX to the MIDI in of the GSP you can control the patch changes on the the GSP via the GCX
Is that what you're trying to do, control the GSP via the GCX??
David Gilmour
bettsaj
Post by bettsaj » Mon Jan 23, 2017 10:37 am
I assume you have a ground control pro plugged into the GCX, so yeah... Control the whole system from the GCP... midi thru of the GCX to the Midi in of the GSP.
David Gilmour
