How to power Ground Link?
warrp
Post by warrp » Wed Oct 28, 2009 5:01 pm
Hi, I have a Ground Link to go with a Ground Control (not Pro) and will be using it into a MOTU MIDI Time Piece II. The manual suggests connecting the Ground Link to a GCX, which will power it through the MIDI connection.
I'm not using a GCX - how can I power the Ground Link?
cheers!
Re: How to power Ground Link?
Post by JohnClark » Fri Oct 30, 2009 9:46 am
The Ground Link accepts phantom power on Pins 1 and 3 of the GCX Out Jack. If you use a 5 Pin active/wired cable between the Ground Control MIDI Out and the Ground Link MIDI In, then the Ground Control will also be powered. You will want to provide 9VAC @ 500mA(minimum).
