GCX and g-major2+pedals
modulo
Post by modulo » Fri Jul 15, 2016 10:01 am
HI,
i would like to know how to program my new GCX to my rig. I have the GCP with 4 presets and running pedal mode in the other 8 switches. I bought and now would like to use real pedals as 1-2-3-4 as real pedal and use the other 4 as ''pedals'' on my g-major2 with CC command?
GCP:
1- chorus (real)
2- flanger (real)
3- phaser (real)
4- overdrive )real)
5- Boost on G-major2 using cc
6- Delay on G-major2 using cc
7- pitch shifter on G-major2 using cc
8- reverb on G-major2 using cc
Real= real pedal
First: Do I have to reprogram my GCP?? since it's all ready program ??
:roll:
Marshall JVM 210H 100w
1960a cab with G12T75 and Vintage 30's
Fractal Audio AX8
Guitars:
IBANEZ JEM PMC
IBANEZ JEMjr Desert Yellow
EVH Wolfgang Vintage white
Re: GCX and g-major2+pedals
Post by JohnClark » Fri Jul 15, 2016 3:40 pm
If you want Instant Access buttons 5-8 to control G-Major Effects Blocks, then yes, you will have to re-program those buttons.
Look to MIDI Continuous Controller On/Off in the Instant Access section under Setup Mode of the Ground Control Pro user manual. This will show you how to program each button for the proper MIDI Channel and set the Control Change number that matches the Effect Block you want to control.
The G-Major2 display will show the Control Change number associated with each Effect Block in the MOD Menu, or it can Learn the Control Change you set on each of the Ground Control Pro Instant Access buttons.
Let us know if you get stuck!
