It is currently Wed Jun 20, 2018 4:47 am
 Post subject: Buttons sticking on Ground Control Pro
PostPosted: Mon May 23, 2016 12:40 pm
I am finding that the bottom four buttons on my GCP are sticking really bad ,is there a way to either clean them or replace them quickly and efficiently ,without totally screwing up anything important.I have tried contact cleaner but that doesn't seem to work or did I make it worse by using that stuff.If they do need to be replaced what is the switch type I need to accomplish this?
 Post subject: Re: Buttons sticking on Ground Control Pro
PostPosted: Mon May 23, 2016 12:54 pm
Sticking? As in the metal button is staying pushed down?
How old is this Ground Control Pro? Did you buy it new?
PostPosted: Tue May 24, 2016 9:36 am
The GCP is an older one ,the buttons are not sticking down ,it seems like isn't making contact to switch from one program to another ,the other 3 work ok(it sometimes takes a couple of taps to get them to change) but one of them just doesn't seem to connect.I did not buy it new.
PostPosted: Wed May 25, 2016 9:56 am
So,from doing a little research I see that this is a common problem with the switches on the GCP where they become intermittent .Apparently from what i can find out is that the visible switches are spring loaded and then hit a second switch which connects to the board under neath and the spring wears out or fails to make adequate contact I have found a replacement of sorts http://www.mammothelectronics.com/4SFSS ... 003.htm,is this something you would recommend?/
Anyone?
PostPosted: Wed May 25, 2016 11:46 am
What version is the firmware in your Ground Control Pro?
I would not recommend the switch you linked... it would require heavy modifications to make that work.
PostPosted: Thu May 26, 2016 8:54 am
i am running version 1.13
PostPosted: Thu May 26, 2016 10:09 am
Please give us a call or write to info@voodoolab.com so we can arrange to have you send your Ground Control Pro in to us for an inspection/repair. Alternatively, we can send you some switches, but if you send it in to us we will do a "full checkup" ;)
Be sure to mention this thread.
PostPosted: Thu May 26, 2016 11:37 am
Ok,will do ,thanks so much John you have been very helpful
