Voltage Input?
kenora
Voltage Input?
Post by kenora » Fri Jul 19, 2013 11:50 am
Does anyone know if the GCX audio switcher can handle a 12v power supply?
nyteowl
Re: Voltage Input?
Post by nyteowl » Fri Jul 19, 2013 12:15 pm
I know the GCX comes with a 9VAC power supply. Personally, I wouldn't risk using a 12-volt power supply, but I'll defer to John for the definitive answer.
Josh Fiden
Site Admin
Re: Voltage Input?
Post by Josh Fiden » Sat Jul 20, 2013 11:10 am
nyteowl wrote:I know the GCX comes with a 9VAC power supply. Personally, I wouldn't risk using a 12-volt power supply, but I'll defer to John for the definitive answer.
You can power the GCX from either 9VAC or 12VDC. A 12V supply is fine if it provides DC, you would NOT want to use a 12V AC supply.
This is because AC power is specified as RMS voltage. The actual peak voltage is about 1.4 times the RMS voltage. So, using 9VAC we get 12V from the GCX's internal power supply.
Regards,
Josh Fiden
Founder / CEO
