polloymedio wrote:
Hello all! Im writing because my ground control is not working! I switch it on and all i get is the red light on on the "EDIT" button, and cant do anything for it! Im using an AXE Fx which gives power to the ground control, and i have no clue of what is happening. (I have used my setup a lot of times, the problem gets worse cause i have a gig tomorrow!)
I tried connecting the adapter alone with the controller and i still get the same problem. Anyone?
If I understand correctly, you have been using your Ground Control with your Axe-FX for a while, this problem has just started, and it doesn't matter how you supply power to the Ground Control - either from the Axe-FX or from the Ground Control's power supply - the problem still persists.
Have you tried disconnecting the Axe-FX and powering up the Ground Control by itself? If the problem goes away, then you're looking at a bad MIDI cable; if not, I suspect there may be an internal issue with your Ground Control.
