It is currently Mon May 20, 2013 10:44 am
Page 1 of 1
[ 3 posts ] |
| Author |
Message |
jmp220478
Post subject: phantom power via 5-7 pin style cable Posted: Mon May 07, 2012 10:13 am |
Im having a custom stage ready midi cables made in UK for AxeFx2 / GCP rg
need the pin configuration for the GCP - which pins carry the power .. ? ( my gcp from 2002 )
I had intended to use my axefx 2 and its 7 pin to 7pin option but would seem this isnt a direct path + hits the axe's midi board with power from the walwart supply for the GCP ( some users have damaged the board with excessive phantom requirement over 1000ma .. so am going 5pin/power Y cable route back to the GCP ..
cheers in advance ...
| Top |
Post subject: Re: phantom power via 5-7 pin style cable Posted: Mon May 07, 2012 2:58 pm |
Joined: Tue May 05, 2009 2:33 pm Posts: 3588 Location: The Lab
| Top |
nyteowl
Post subject: Re: phantom power via 5-7 pin style cable Posted: Fri Aug 10, 2012 8:53 am |
Here is a link to a post on the Fractal Forum regarding the Axe-FX 7-Pin MIDI Pinout.
This information, when combined with the info John has already provided, should be enough for whoever is making your stage ready MIDI cables to construct a custom 7-pin cable to run directly from your Axe-FX2 to your GCP.
_________________ I can't read the manual for you, but odds are that's where I found the answer to your question.
| Top |
Page 1 of 1
[ 3 posts ] |
Who is online |
Users browsing this forum: Google [Bot] and 2 guests |
