Embree wrote:
Looking to run the G major 2, dbx 266xs compressor/gate, tc electronic m350 reverb processor and effects floorboard through GCX and then all individually controlled through the GCP... The effects on the floorboard id like to control on my own but still controlled through the GCX.
Any thoughts an guidance would be greatly appreciated!
Okay, I'm a little confused. By "effects floorboard" do you mean a pedal board with a number of effects pedals on it and could you elaborate on "The effects on the floorboard id like to control on my own but still controlled through the GCX?" If you intend to control them by yourself, how does the GCX come into play? Do you want the board itself in a single loop so you can use the GCX as a Master On/Off control for the entire effects pedals signal chain, or do you want the pedals themselves in individual GCX loops so you can activate/deactivate them independently while controlling each respective pedal's parameters by hand?
As for the three rack processors, if you're running them Mono you can just put them in GCX loops in whatever order you desire. However, if you want to run them in stereo, you'll need to use one loop for the left channel and a second loop for the right channel unless you have a stereo GCX, in which case you would be using stereo cables or insert jacks. If you prefer running the G-Major in the FX Loop of your amp, just connect the amp's FX Send to the In jack of any loop, the Send/Return jacks to the In and Out jacks of the GM2, and the Out jack of that loop to your amp's FX Return jack.
Hope this helps...
