It is currently Sat May 25, 2013 9:19 pm
Page 1 of 1
[ 2 posts ] |
| Author |
Message |
bri2810
Post subject: GCP & GCX Posted: Thu Dec 01, 2011 1:50 am |
Hi Guys . I have just brought a new GCX and a secondhand GCP , but when I connect the 2 via the 5 pin cable the GCP will not power up . if I use the seperate power adaptor it works .But Even when powered up the GCP is not talking to the GCX ( no lights on ) , any ideas .
cheers Brian
| Top |
Post subject: Re: GCP & GCX Posted: Fri Dec 02, 2011 12:24 pm |
Joined: Tue May 05, 2009 2:33 pm Posts: 3591 Location: The Lab
Make sure that the cable you are using actually has all 5 pins wired. The cable packaging will usually be labeled "5-Pin Active" or "5-Pin Wired".
You should also make sure that the cable end connected to the Ground Control Pro MIDI Out is aligned properly. It is possible to force a 5-Pin cable into the 7-Pin jack with the pins misaligned.
 Voodoo Lab ® Tech/Magician
| Top |
Page 1 of 1
[ 2 posts ] |
Who is online |
Users browsing this forum: Google [Bot] and 5 guests |
