It is currently Wed May 22, 2013 10:47 am
 Post subject: need help with GCP
PostPosted: Sun Nov 27, 2011 10:18 am
im using the GCP with the eleven rack.. i have it set up with 4 patch changes at the bottom and 8 effects programmed at the top. here is the trouble im having -- say if im on patch 1 "clean" and have chorus and verb on with red lights lit up, when i switch to crunch or others and come back to clean, the red lights are not lit up and i have to turn all effect back on. basicly effects are not staying on when i switch patches..is this a GCP problem or an eleven rack problem?
 Post subject: Re: need help with GCP
PostPosted: Mon Nov 28, 2011 12:44 pm
You must program the state of the Instant Access buttons within your Ground Control Pro presets.
To make the Instant Access button status match the effects that are active on a given preset:
1. Call up the Ground Control Pro preset that you want to edit.
2. Press any of the Instant Access buttons that should be on for this preset.
3. Press and hold the EDIT button.
4. Once the Ground Control Pro screen changes, press the EDIT button again.
5. Press the YES button to save the changes.
6. Repeat steps 1-5 for each Ground Control Pro preset that has active effects.
Voodoo Lab ®
Tech/Magician
PostPosted: Mon Nov 28, 2011 2:50 pm
thanks john !! worked like a charm :D
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
