It is currently Sat May 18, 2013 2:18 pm
Post new topic Reply to topic  [ 14 posts ]  Go to page 1, 2  Next
 Post subject: Volume pedal/G- Major 2
PostPosted: Sat Aug 27, 2011 5:10 pm
hi there
I wanted to search this forum but turned out to be too many topic about volume pedal.
I play one channel hardwired amp
I have G-Major 2
I have GCP/GCX
Volume pedal into GCP would not work.Cable is correct
Does this has anything to do with G-Major?
I am asking last question as amp does reach certain volume and after that even volume on amp will not effect overall volume.
I would appreciate any help
 Post subject: Re: Volume pedal/G- Major 2
PostPosted: Mon Aug 29, 2011 10:05 am
Connecting a pedal to the Ground Control Pro will make it act as a MIDI expression pedal. Your G-Major 2 is the device that will receive the MIDI expression control and perform whatever function you have programmed within the G-Major 2. Check that you have the G-Major 2 set up to control volume within its MOD Menu.
Voodoo Lab ®
Tech/Magician
PostPosted: Mon Aug 29, 2011 10:17 pm
Are you saying my volume pedal will act like Wah through G-major's wah pare-miter?
PostPosted: Tue Aug 30, 2011 5:51 am
Are you sure you assigned the expression pedal in each patch of the GCP as well as assigned it to global volume in the G-Maj?
Dom
PostPosted: Wed Aug 31, 2011 10:03 am
Yes, a guitar volume pedal becomes a MIDI expression pedal when connected to a Ground Control Pro allowing you to control any parameter that your MIDI device allows. Each Ground Control Pro preset can control a different parameter if you wanted.
Voodoo Lab ®
Tech/Magician
PostPosted: Sat Sep 03, 2011 9:22 pm
Dom
Could you please make it more clear for me?
PostPosted: Wed Sep 07, 2011 2:59 pm
On the Ground Control Pro you will set the Expression Pedal to send on a specific Control Change number that must match the Control Change number for the parameter you wish to control. Detailed information on this is found in the Using Expression Pedals section of the Ground Control Pro manual under Edit Preset.
On the G-Major (1 and 2) you will assign the expression pedal to control one of Mods 1-4, then assign the programmed Mod to the parameter you want to control. These settings are found in the External Control Using Modifiers section of the G-Major 2 manual under MOD Menu.
Let us know if you get stuck anywhere!
Voodoo Lab ®
Tech/Magician
PostPosted: Thu Sep 08, 2011 8:10 pm
Thank you John
You have been very kind to everybody here.I do not know how do you find strength to deal with us that are sometimes.....just dumbasses
Anyways ......
I got volume pedal to work.But it does not give me volume up for soloing.It just turn off volume and then when i press it again it comes up to previous volume levels.
I would appreciate if you can help me out
Rock on ....
PostPosted: Mon Sep 12, 2011 9:58 am
Are you using an on/off button or a rocker type pedal for this?
There are two ways to get "solo boost" with a G-Major2.
One is to assign an Instant Access button to control the PresetBoost parameter.
The other way is to program an expression pedal to control the Preset Out Level, however achieving "boost" with an expression/volume pedal would really be only putting it all the way toe forward when you wanted it "louder". ;)
Voodoo Lab ®
Tech/Magician
PostPosted: Tue Sep 13, 2011 8:38 pm
I am using rocker type pedal.But as i said it does not give me real volume boost.It just take volume on and off.
