DMC GCX vs Voodoolab GCX
gerax
Post by gerax » Thu Mar 24, 2011 4:46 am
So, what's the actual difference between pre Voodoolab and post of the same type of switcher?
Did relays or other components change? Is sound quality the same? I belive control facilities with GC firmware update to the latest version should be the same...
I'm asking because I'd likely get an used GCX from the DMC era, so I'd like to know what's changed besides the logo...
Thanx
Re: DMC GCX vs Voodoolab GCX
Post by JohnClark » Thu Mar 24, 2011 9:59 am
If the front panel jacks read Guitar In and Feedthru then the only difference is the logo.
