GCX: all loops on by default?
Duffman
Post by Duffman » Thu Feb 03, 2022 5:55 am
Hi all, my question is basically in the title; is there a way to set the GCX’s default boot state to be all loops on?
Why? Cause I’ve been toying with the idea of building a pedal board, with the GCX mounted under so I can play and tweak easily at home, and then, with zero fuss, just plug in the ground control and have the pedal board / GCX somewhere safe at gigs. I know this isn’t the standard usage of this setup but I’m trying to experiment and not buy things I don’t need.
Thanks for any thoughts.
