Multiple GCX controlled via daw (pro tools)
marcodeangelis
Post by marcodeangelis » Wed Feb 02, 2022 9:10 am
Hello everybody out there, I'd need to know if someone has anyis going to be a problem when you use more that one GCX cause all the GCX will react at the same control change message. I need to slave the loops of multiple GCX to a Pro Tools session (but it's the same for any DAW). Any idea? Thanks in advance.
