GCX DC Power Consumption
PHLTHS
Post by PHLTHS » Sat Mar 30, 2019 2:12 am
Hi Voodoo Labs
I’ve recently purchased 3x GCX Audio Switchers and a GCP unit.
I want to clean up the power cables as much as possible so I’ve been reading that the GCX can be powered by either 9VAC or 12VDC from previous posts.
I wanted to find out what is the current consumption requirements of a GCX on its own and also when the GCX is phantom powering a GCP when using 12VDC?
Does Voodoo labs have any power supply that I can purchase to power up all my GCX switchers and phantom power my GCP?
Thank you.
Marlboro05
Re: GCX DC Power Consumption
Post by Marlboro05 » Sat Mar 30, 2019 10:36 pm
Hi there, I’ve got the Voodoo Lab Pedal Power AC, it has 4 x 9v and 2 x 12 v (either 9 or 12 v can only be used for 2 of the ports). I power 1 GCX, I have 2 and have powered them both, I also have 2 x GC Pro’s running through phantom power off the GCX. I have modified one of the the GC Pro’s so that the power goes from Midi out to Midi in. I have used this like it for a year now with no drama.
I actually power a Decimator Pro Rack G Stereo mod, a RJM Mini Switch Gizmo and the GCX, which in turn does the 2 x GC Pro’s.
Cheers Brett
And some other stuff.
PHLTHS
Post by PHLTHS » Sun Mar 31, 2019 6:50 pm
Hi Brett
Thanks for that. I still would like to know what the current draw of the GCX with and without a GCP using 12VDC in case I can find a larger power supply to run the lot plus my other gear.
I believe in other posts John says that the GCX @ 9VAC draws 400mA and with a GCP attached it draws 800mA
So I believe switching to 12VDC, they should be 333mA and 666mA respectively?
Post by JohnClark » Mon Apr 01, 2019 11:07 am
I'm not sure I've measured for exact but I'd still stick with the safe minimum of 400mA for a GCX. If providing Phantom Power to a Ground Control Pro I'd say the 800mA is the safe bet. The important thing is that from a DC source the GCX must see 12VDC... at 9VDC the relays will not always trigger :shock:
p.s. We use AC power for these since it won't suffer as much of a Voltage Drop across the length of the MIDI Cable. To a DC supply, the MIDI Cable carrying the Phantom Power will look like a resistive load and add to the overall current draw. The longer the cable, the bigger the load.
PHLTHS
Post by PHLTHS » Tue Apr 02, 2019 2:07 am
Hi John
Thank you for getting back to me.
Last question, would you see any issue with the following configuration?
1x GCX + GCP running on 9VAC
2x GCX running on 12VDC?
Any issues with each unit running on different types of voltages but all interconnected via MIDI?
Thank you
Post by JohnClark » Tue Apr 02, 2019 9:20 am
That shouldn't be a problem at all. Only the first GCX will be sharing the power via Phantom Power... the other two won't use the powered pins on the MIDI connections.
