See gcx, loop and ohms?
PabloArancibia
Post by PabloArancibia » Fri Nov 26, 2021 9:08 pm
Hi, I can use a gcx loop to select the 8 ohm speaker output from two amps. I do not know if I explain myself very well. Thanks
Marlboro05
Re: See gcx, loop and ohms?
Post by Marlboro05 » Thu Dec 02, 2021 12:58 pm
No, the relays can’t handle that current.
And some other stuff.
