Voodoo Lab
GCP stuck on GCX in instant access mode
http://www.voodoolab.com/forum/viewtopic.php?f=8&t=8705
Author:  Scooter13 [ Fri Dec 29, 2017 10:44 am ]
Post subject:  GCP stuck on GCX in instant access mode
When attempting to set up my 8 pedal buttons, when I go into "Instant Access"... All I get are the 8 GCX Loop options?? I have the GCX disable in the extenders portion and I cannot figure out how to get to the normal CTRL CC screen for setting up buttons with my Eleven Rack
Any help??? I tried everything I could find before jumping on here....
Author:  tijlcarrein [ Sat Dec 30, 2017 9:50 am ]
Post subject:  Re: GCP stuck on GCX in instant access mode
Hi There, it's in the manual page 11:
- Hit both setup buttons to enter setup mode and select the instant access button (button 6).
- With the cursor on the GCX #, press [+/YES] until the display shows: 1.CH01 CTL004; This indicates that Instant Access button #1 will control MIDI continuous controller #004 on channel 1
- You can use [CURSOR >] to move between the channel and the controller number
- Then use [-/NO] and [+/YES] to select MIDI channels 1-16 and continuous controllers 0-120.
- If you press [CURSOR >] again, you can select between NORMAL, XMIT W/PRSET and MOMENTARY. Here’s what that means:
NORMAL
The CC message is only sent when you press the instant access button. You press it once to turn it on, then again to turn it off.
XMIT W/PRSET
This stands for “Transmit with Preset”. When you call up a preset on the Ground Control Pro, it will send out the current state (on or off) of this instant access button. Of course it turns on and off when you press the button too.
MOMENTARY
This option means that it sends an “on” message when the instant access button is pressed, then sends an “off ” message when it is released.
Use bank down to select instant acces button 2 so the dsplay reads 2.CH01 CTL###
Use bank down to select instant acces button 3 so the dsplay reads 3.CH01 CTL###
and so on..
When all IA's are configured, push the setup button to exit setup mode. That's it! The instant acces buttons are global for all patches. Don't forget to enable pedal 1 and/or pedal 2 if you want to assign a CC for volume/wah/pitch. This needs to be set per preset (wich is great because e.g.: in my bank 0, preset 3, pedal 2 can be wah (CC1 in my Kemper) and in preset 4 it can be pitch (CC4 in my kemper)...
Really love this midi pedal!
http://www.phpbb.com/
