Daisy Chain with Pedal Power 2 Plus?
Universe326
Post by Universe326 » Mon Aug 03, 2009 1:22 pm
Hi, is it possible to run a daisy chain off a Boss TU2 tuner when it is being powered by the PP2P? I have tried this so far it seems not to work. Any suggestions?
Re: Daisy Chain with Pedal Power 2 Plus?
Post by JohnClark » Tue Aug 04, 2009 12:08 pm
Not sure what you tried to power but it should at least work for one or two low current pedals. Remember that the Pedal Power 2+ outputs are limited to either 100 or 250mA depending on the output used. Add up the current demand of each pedal and the tuner to find out if you are under the max. It is also possible that there is a ground lift happening which would require that all the audio cables are connected before all the pedals would power up.
