It is currently Sat May 25, 2013 6:52 pm
 Post subject: Fulltone Clyde, Morley Little Alligator and GCP
PostPosted: Mon Apr 23, 2012 3:01 pm
Hi, Can i conect a Fulltone Clyde standard Wah and Morley Little Alligator Volume pedal on the Ground Control Pro? o Maybe in the GCX?
 Post subject: Re: Fulltone Clyde, Morley Little Alligator and GCP
PostPosted: Tue Apr 24, 2012 12:33 pm
If anything these would connect to either the GCX or a Pedal Switcher. However, given that you must put your foot on these to use them, and that the Clyde is true-bypass anyway, I would simply connect the guitar signal directly to these pedals then off to wherever it would otherwise go. *Of course, this depends on exactly where you want these pedals routed in your signal path. ;)
The ports on the Ground Control Pro are for passive volume or expression pedals. These ports are used only to convert the pedal movement into a MIDI signal to control parameters on a capable MIDI device.
Voodoo Lab ®
Tech/Magician
