It is currently Sat May 25, 2013 6:57 am
 Post subject: sparkle drive problem
PostPosted: Thu Jul 21, 2011 5:22 pm
My sparkle drive is messing up. I plug it in and it bypasses fine but when i turn it on all i get is a static sound.... any help will help.
thanks
-Dane
 Post subject: Re: sparkle drive problem
PostPosted: Thu Jul 21, 2011 5:52 pm
How are you powering the Sparkle Drive? Do you get the same behavior when connecting your guitar directly to the Sparkle Drive and the Sparkle Drive directly to your amp? If you repeatedly press the bypass switch does the signal return to normal?
Voodoo Lab ®
Tech/Magician
PostPosted: Thu Jul 21, 2011 7:19 pm
i am powering it by a 1spot. and no matter how its plugged in (thru pedals or straight to amp) it still just sends the same static. and i have tired using it several times bc it one of my favorite pedals but it never works... btw thanks for getting back to me so quickly
PostPosted: Fri Jul 22, 2011 9:56 am
Do you see the same behavior when powering it with a battery?
If so, please give us a call or write to info@voodoolab.com so we can discuss your repair options.
Voodoo Lab ®
Tech/Magician
PostPosted: Fri Jul 22, 2011 10:49 am
right now i am away from my pedal at the moment but the i checked to see if the 1 spot plug in was the problem but it worked with all my other pedals.... so im guessing its the SD.. i sent an email over there last night just waitin for a reply
PostPosted: Fri Jul 22, 2011 1:16 pm
hey i got up with ben in tech support and he is helping me out.
thanks for the help
PostPosted: Mon Jul 25, 2011 4:09 pm
I'm having the same problem right now. Hopefully i can get mine fixed!
