It is currently Fri May 24, 2013 2:33 pm
[ 2 posts ] |
| Author |
Message |
cazyapjazz
Post subject: digitecht whammy, tc nova drive, boss slicer, boss rc 50... Posted: Sun Jan 09, 2011 9:07 am |
digitecht whammy, tc nova drive, boss slicer, boss rc 50, boss slicer, moogerfooger ring modulator
is it possible to power all these with one or two voodoo lab products.. and if yes which ones...
thx
| Top |
Post subject: Re: digitecht whammy, tc nova drive, boss slicer, boss rc 50 Posted: Fri Jan 21, 2011 12:49 pm |
Joined: Tue May 05, 2009 2:33 pm Posts: 3590 Location: The Lab
Unfortunately you cannot power all of these from a single unit as they all require the same high current outputs or require AC power.
The Whammy requires AC power and can be powered from the Pedal Power AC.
The Nova Drive can be powered from the 12V output of an ISO-5, or by using a Current Doubler cable connected to both outputs 5 and 6 on a Pedal Power 2+ with the DIP switches set away from Normal.
The Boss Slicer can be powered from the high current 9V output of an ISO-5, or by a Pedal Power 2+ on output 5 or 6 with the DIP switch set to Normal.
The RC-50 can be powered using a Current Doubler cable connected to both outputs 5 and 6 on a Pedal Power 2+ with the DIP switches set away from Normal.
 Voodoo Lab ® Tech/Magician
| Top |
[ 2 posts ] |
Who is online |
Users browsing this forum: Bing [Bot] and 1 guest |
