It is currently Tue Jun 18, 2013 8:27 pm
 Post subject: Switching between more than 2 amps?
PostPosted: Sun Oct 17, 2010 6:39 am
All examples on the Controller/Pedal Switcher seem to indicate that only two amps can be A/B'd using Loop 4. Could you not loop, say two additional amps by sending via Loop 3 and Loop 2. Now, getting signal to more than one amp at the same time would require a splitter at one of these loop outs, but, also doable provided you have more than on Input for a given amp channel?
What am I missing? How could this go wrong? Thanks
 Post subject: Re: Switching between more than 2 amps?
PostPosted: Thu Oct 21, 2010 10:31 am
The Send jacks can be used to have a switchable signal route, however only one can be active at any time. The possibility of ground loop buzz exists as the loops all share a common ground. I hope that helps!
Voodoo Lab ®
Tech/Magician
