Privateguitartuition wrote:
have i wasted my money then getting a pedal switcher and commander? also i would like to keep my delays, wahs, univibes on show. for accseses to making the crazy sounds. but the others i could put in a pedal tray. could you explain how exactly how the ground control pro works. im a bit thick.
also i wanted some explanation of where wahs and all that would go. or doesnt it matter?
I'm not saying you wasted your money. However, was just informing you that if you plan to build a rig of this size that you may want to consider a full featured controller/switcher that will best suit the needs of a rig this size.
The Ground Control Pro can send out 8 different Program Change messages on 8 different MIDI channels upon preset change. It also has the 4 Presets Per Bank mode, which makes buttons 1-8 into "instant access" buttons. With IA buttons you can assign them to individual effects within an effects processor and bypass/unbypass them as if they were stomp boxes. They can also be used to switch GCX loops on/off while the preset buttons can switch different combinations of GCX/Pedal Switcher loops on/off.
