US VOODOOLAB POWER convert to EUROPE
Elelvis83
Post by Elelvis83 » Sun Jan 06, 2019 12:04 am
Please , i juste bough a voodoolab pedal power in New York (120V) but the problem is i live in Europe wich is (220v) ,
What Can i do ??
Re: US VOODOOLAB POWER convert to EUROPE
Post by Rez » Tue Jan 08, 2019 5:45 pm
A 120VAC model will be damaged if powered at 220-240VAC.
However, you could use Pedal Power 2 Plus with an appropriate step up/down transformer for the area in which you will be playing.
I don't have a specific recommendation, sorry, but maybe something rated about 200 watts (a big/heavy high power model is not necessary).
Here are some links to step up/down transformers which might be useful:
step transformer ex.1
step transformer ex.2
step transformer ex.3
step transformer ex.4
Alternatively, you might consider purchasing an export model Pedal Power 2 Plus from a dealer located in the region it will be most often used. Here the dealers link: Voodoo Lab Dealers
