It is currently Fri Apr 20, 2018 1:36 am
 Post subject: Pedal Power ISO5 dimensions
PostPosted: Thu May 07, 2009 9:55 am
I'm putting a new board together and plan to buy an ISO5 as soon as it's available. I'd like the dimensions so I can leave the right amount of space.
Nathan
 Post subject: Re: Pedal Power ISO5 dimensions
PostPosted: Thu May 14, 2009 1:28 pm
I feel neglected. Any info available?
Nathan
PostPosted: Thu May 14, 2009 7:18 pm
Site Admin
Hi Nathan,
Sorry you feel neglected! The Voodoo Lab forum has only been up a very short time, but we've had quite a few posts. It's great to see so much interest!
The Pedal Power ISO-5 will be 4.9" (124mm) wide x 3.4" (86mm) deep x 1.75" (44mm) tall.
Regards,
Josh Fiden
Founder / CEO
PostPosted: Thu May 14, 2009 10:20 pm
Thanks a million. Now to build a cardboard box that size to work around ...
PostPosted: Tue May 19, 2009 11:17 pm
Looking forward to powering my T-Rex Replica with this. When are these shipping and since it is the same depth and height, but not as wide, as the PP2, can it still be mounted under the Pedaltrain Jr with the included mounting brackets? Thanks!!
PostPosted: Wed May 20, 2009 12:03 am
Site Admin
We're still finalizing the design, so no formal release date yet. It will definitely fit under the Pedaltrain.
The PP2+ can also power the Replica from outputs 5 or 6 with the DIP switch set away from normal.
Josh
PostPosted: Wed May 20, 2009 8:14 am
Thanks Josh!!... one other question, the T-rex solution for slots 5/6 with the dip switch on works with the PP2+ and not the PP2, correct? Thanks for your help.
