HX Stomp and PP2 AC auxiliary
Posted: Thu Oct 25, 2018 10:47 am
by KLGI
Is it ok to use a PP2+ Auxiliary to plug in the line 6 HX stomp to my board?
According to their manual, their draw is 9VDC 3A
thanks for your time
Re: HX Stomp and PP2 AC auxiliary
Posted: Thu Oct 25, 2018 4:44 pm
by Rez
Yes, it's perfectly fine to power your HX Stomp (with its adapter/wall-wart) from the Pedal Power 2 Plus AC courtesy outlet.
Cheers!
Posted: Fri Oct 26, 2018 6:07 am
by KLGI
Thanks Ben
PS-support from you guys has always been great
Posted: Fri Oct 26, 2018 11:22 am
by Rez
Thank you ;)
Posted: Sat Feb 09, 2019 7:51 am
by The Plunders
I'm using the courtesy/aux on a PP2 to power my HX Stomp but the orientation of the Line 6 adapter causes it to stick straight up. Is there an adapter of some sort that can turn the PP2 aux output 90 degrees so that the HX Stomp adapter runs parallel to the front of the pedal board? Anyone had this issue? Found a solution?
