outlet in the pedal power 2 to power an OCD with 18VDC 150mA
nando
Post by nando » Thu Dec 31, 2009 12:21 am
is it possible to use the back outlet in the pedal power 2 to power an OCD with an 18VDC 150mA adaptor?
Josh Fiden
Site Admin
Re: outlet in the pedal power 2 to power an OCD with 18VDC 150mA
Post by Josh Fiden » Mon Jan 04, 2010 12:05 am
nando wrote:is it possible to use the back outlet in the pedal power 2 to power an OCD with an 18VDC 150mA adaptor?
That will work fine. You can also use a Y-cable which combines two 9V outputs in series to get 18V. We have a cable to do this, or you can make your own.
Regards,
Josh Fiden
Founder / CEO
bloombaber
Post by bloombaber » Mon Nov 29, 2010 11:33 am
I'm confused. My OCD power jack says "9VDC to 18VDC" but I keep seeing it discussed here with 18V connections. Can't I just plug it into the standard 9V port on my Pedal Power 2+?
Mike B.
Pedal Noob
Josh Fiden
Site Admin
Post by Josh Fiden » Mon Nov 29, 2010 7:58 pm
bloombaber wrote:I'm confused. My OCD power jack says "9VDC to 18VDC" but I keep seeing it discussed here with 18V connections. Can't I just plug it into the standard 9V port on my Pedal Power 2+?
Mike B.
Pedal Noob
Yes, it works fine at 9V. Some people prefer it at 18V.
