Possible to power Gigrig G2?
Veritheon
Post by Veritheon » Fri Feb 02, 2018 7:10 am
Is it possible to power Gigrig G2 with pedalpower 2 plus, with 200 watt max output?
Re: Possible to power Gigrig G2?
Post by JohnClark » Fri Feb 02, 2018 11:00 am
No problem at all! Plug it in already! ;)
Veritheon
Post by Veritheon » Tue Feb 06, 2018 8:35 am
JohnClark wrote:No problem at all! Plug it in already! ;)
Can you tell me what cables should i use?
Post by JohnClark » Tue Feb 06, 2018 10:42 am
If you are using a US model Pedal Power then you will need only a standard IEC cable to connect from the Courtesy Outlet on the back of the Pedal Power to the AC inlet on the Generator.
If you are using an Export model Pedal Power then you will need a "Reverse IEC" or "IEC Extention" cable to connect from the Courtesy Outlet on the back of the Pedal Power to the AC inlet on the Generator.
Let us know if you get stuck!
