Hi! Which PP2+ outlets must I use for a Digitech Whammy V that requires 9VDC 1.3mA and an MXR Boost Overdrive MC402 that requires 9vdc 5.5mA according to the manual?
Hi! Which PP2+ outlets for a Whammy V and an MXR Boost MC402
Re: Hi! Which PP2+ outlets for a Whammy V and an MXR Boost M
The Whammy 5 would be best to power using a Current Doubler Adapter (the one with the Green end) connected to Output 5 or 6 and any other Output with the corresponding DIP Switch set to Normal.
The MC402 can be powered from any output with the corresponding DIP Switch set to Normal.
