It is currently Sat May 26, 2018 10:17 pm
 Post subject: Pedal Power Mondo Questions
PostPosted: Mon Apr 06, 2015 7:04 am
I'm looking to buy a Pedal Power Mondo and had some questions in regards to how it would handle my setup.
My pedalboard is as follows in no particular order:
Digitech Whammy 5
Pigtronix Mothership
Pigtronix Philosopher King
Moog Clusterflux
Moog MF-Drive
Moog MF-Boost
TC Electronics Polytune
Line 6 M5
Electro-Harmonix Superego
Molten Voltage Tempode
Molten Voltage CV-Sync
Molten Voltage Splitty
The eight pedals below the Clusterflux, I believe that I should be able to use the "1-8" power supplies without a problem. It is the other 4 pedals that I am curious about.
I believe that since the Whammy is 1300mA, that I will need to use the courtesy outlet, is this correct?
The Pigtronix Mothership is one of the newer models that uses a 18V, 300mA power supply. Could I combine the first two high current outputs for this? If so, do I need to change any dip switches or anything? Also, can you let me know specifically which cable that I would need to buy for this to make it work?
The Philosopher King is the exact same power supply as the Mothership, so I basically have the exact same questions for this one except that I'm assuming that I could combine the 3rd and 4th hight current outputs here.
The Clusterflux uses a 9V, 400mA power supply, so I assume that I can use the 5th high voltage supply for this. I seem to remember that the Moogerfooger pedals use a different type of cable though. Can you point me to where I could buy this as well?
Thanks SOOOOO much!!!
 Post subject: Re: Pedal Power Mondo Questions
PostPosted: Mon Apr 06, 2015 7:28 am
Just realized that the M5 will need a high power output too. My bad :)
PostPosted: Wed Jan 17, 2018 12:02 pm
thom wrote:
...I'm looking to buy a Pedal Power Mondo and had some questions in regards to how it would handle my setup.
Hi thom, I'm new in this forum and I've checked you have almost the same pedals as me and also want to buy the Mondo.
I'm worry about 3 moogerfoogers (Ring Modulator, Analog Delay, FreqBox), BlueSky and a Boss ES8, because I bought a custom power supply but I get hum or other noises, I think it's because of the moogs and its high current consumption.
I want to know how did the Mondo go for you?
My pedalboard setup:
Boss - ES8
Boss - Metal Core
Digitech - Whammy 4
Moog - FreqBox
Moog - Ring Modulator
Moog - Analog Delay
Electro Harmonix - Russian Big Muff Pi
Dunlop - Cry Baby Bass
MXR - M87 Bass Compressor
TC Electronic - Ditto Looper
TC Electronic - Polytune
Strymon - BlueSky
ZVex - Fuzz Probe
Thanks in advance!
Rodrigo Narcía
