Voodoo Lab
Current Doubler on the Pedal Power 4x4
http://www.voodoolab.com/forum/viewtopic.php?f=7&t=8513
Author:  Joris [ Fri Oct 20, 2017 10:48 am ]
Post subject:  Current Doubler on the Pedal Power 4x4
I have a Kingsley Page and Harlot ...each need 800mA 9V.
Can I use 2 current doublers on 1 4x4 power block ( on the 4 high current outputs 9V, 400mA)
Thx !
Author:  JohnClark [ Fri Oct 20, 2017 11:58 am ]
Post subject:  Re: Current Doubler on the Pedal Power 4x4
The actual current draw for each of these pedals is under 500mA. You can use one 9V High Current output combined with any other 9V Output using a Current Doubler Adapter (the one with the Green end) on a 4x4 to power each one. No problem running two at the same time... in fact you could run four of them if you wanted ;)
Author:  Joris [ Fri Oct 20, 2017 2:26 pm ]
very helpful indeed !
Thank you.
Joris, Belgium
http://www.phpbb.com/
