It is currently Sat Feb 17, 2018 2:11 pm
 Post subject: Powering dl4
PostPosted: Wed Aug 16, 2017 5:34 pm
I just bought a used line 6 dl4 from craigslist. It worked perfectly at the guys house on a one spot. However, since I got it home, I can't get it to turn on. I have a pedal power, not the plus, and a red tipped cable from voodoo labs. I tried it on every plug and tried them all with the switch on and off. I'm not sure what else to do here. Any advice would be much appreciated.
 Post subject: Re: Powering dl4
PostPosted: Thu Aug 17, 2017 1:44 pm
With a Pedal Power 2 you should be able to power a DL-4 from output 5 or 6 with the corresponding DIP switch set away from Normal. No other output or setting will work.
Has this DL-4 been modified that you know of?
