It is currently Sun Feb 25, 2018 8:36 pm
 Post subject: PP AC - Digitech Whammy WH-1
PostPosted: Thu Dec 03, 2009 9:16 am
Hi
Just bought a PP AC and just wanted to make sure I was using the correct output port for the WH1. I assume its the 9V (1200ma) one that I use.. but reading the WH 1 manual it says it runs off 10V.
Regards
 Post subject: Re: PP AC - Digitech Whammy WH-1
PostPosted: Thu Dec 03, 2009 12:40 pm
Ok, plugged in the 9V (1200ma) output tonight and it seems ok. Sounds much cleaner than the oem wallwart to :D
PostPosted: Thu Dec 03, 2009 5:20 pm
You got it... the Whammy should be powered from one of the two higher current 9V outputs on the Pedal Power AC.
