It is currently Fri Jun 22, 2018 3:52 am
 Post subject: Earthquaker Avalanche Run and Eventide H9
PostPosted: Wed Jul 12, 2017 10:55 am
Searched all over and can't find an answer to this: has anyone successfully powered an Avalanche Run with a VL supply? The specs say it has a 425ma draw.
Will one of the 400ma outs on a 4x4 work? Or should I use a current doubler to combine one of the 400ma and one of the 100ma outs?
I'm also trying to power an H9 which requires 500ma (also center positive 2.5mm). If I did the same thing with that I'd use up half my outs just with those two pedals which would leave me short for the rest of my board.
Do I need to look at a Mondo?
Any other options that would just involve using one output for each?
Or maybe the easiest thing is a small power strip and use the AC jack for these two pedals...
 Post subject: Re: Earthquaker Avalanche Run and Eventide H9
PostPosted: Mon Jul 17, 2017 9:49 am
I just measured an Avalanche Run to be certain, and I have previously measured an H9 with the Max update. Each of these will be perfectly fine to power from a single 400mA output. They each actually draw less than 400mA.
Users browsing this forum: Baidu [Spider] and 6 guests
cron
