PP2+ with a Boss RC50 loop station?
The Blue Letter
Post by The Blue Letter » Mon Nov 30, 2009 3:39 pm
I have a Boss RC50, a Boss RC20XL, two Line 6 modeler pedals (DL4 +FM4) and two boss stomp boxes (DSD-3 and DF-2). can the PP2+ handle it?
loud, louder, loudest
Re: PP2+ with a Boss RC50 loop station?
Post by JohnClark » Wed Dec 02, 2009 11:11 am
The two Line6 Modelers can be powered from outputs 5 and 6 switched away from Normal for L6 mode. The DF-2 can be powered from an output 1-4 switched away from Normal for ACA mode. DSD-3 and the RC-20XL can be powered from any of the outputs switched to Normal. The RC-50 can be powered from the Courtesy Outlet using the supplied Boss adapter.
The Blue Letter
Post by The Blue Letter » Wed Dec 02, 2009 2:11 pm
Hey John,
Thanks for the reply. I am going to need a power supply for the pedals in my rack too, and am sure on the boss pedals, but I also have an EHX Holy Grail, a Guyatone, VT-X (their tube tremolo) and an EHX HOG.
I am pretty sure that the Holy Grail will be fine since it is also a 9v pedal, The HOG is too, but it's 500ma. Can the PP2+ handle that? And also the Guyatone is a 12vdc/200 mA (Center -/Sleeve +) Please let me know. Thanks a lot.
Dan
Post by JohnClark » Wed Dec 02, 2009 5:59 pm
This is the last time buddy! ;)
The VT-X can be powered from output 5 or 6 switched away from Normal. The Holy Grail can be powered from Output 5 or 6 switched to Normal. The HOG will have to be powered using the supplied adapter from the Pedal Power 2+ Courtesy Outlet or wherever else there is mains power in your rack. Good luck, and take some pics for us when it is all done.
The Blue Letter
Post by The Blue Letter » Wed Dec 02, 2009 8:53 pm
Hey John,
Thanks a lot for the info and help. I will definitely take some pics when everything is fixed up and running. Thanks again.
Dan
