It is currently Thu Apr 26, 2018 7:57 am
Page 1 of 1
[ 3 posts ] |
Author |
Message |
torontomusician
Post subject: Newbie Girl. Hope I have this right Posted: Fri Nov 27, 2009 8:29 pm |
Hey Guys, Boy am I ever glad I found you all. I have done all kinds of research and reading, bought the PedalTrain and the Pedal Power 2 Plus and can't wait to use it. Drilled the brick into the pedaltrain and now I _think_ I have the proper configuration but before plugging everything in I think it might be best for me to check before the test drive.
This is what I have and I think it is supposed to go like this: Maxon AD999 ( goes in #5or 6 - the Line 6 spot, standard cable away from normal) BOSS CE3 (ACA needs to go in outputs 1-4) standard cable away from normal) BOSS PN2 (any output dip normal, standard cable) IBANEZ TS9 (any output, standard cable, normal dip) Fulltone Standard Clyde Wah (neg tip, any output, standard cable, normal dip) Digitech Digiverb (standard cable, any output, dip normal) Red Witch Moon Phaser: The maker's manual says adapter shoudl be BOSS PSA Barrel Positive so I believe I use the positive barrel connection (the 3.5) but what output should this go into.
So how is that? How close am I to success????
If you have a sec to reply, that would be awesome. I can't wait to try it out. It's the first time I have been able to have all my pedals on a real board not to mention the amazing power supply. Thanks guys and gals.
Top |
Post subject: Re: Newbie Girl. Hope I have this right Posted: Mon Nov 30, 2009 11:55 am |
Joined: Tue May 05, 2009 2:33 pm Posts: 6966 Location: The Lab
You are very close... The AD-999 as well as the Moon Phaser can be powered from any output switched to Normal using the standard barrel cable. Actually it appears that all your pedals will use the same standard barrel cable. The CE-3 is the only one that will need to be switched away from Normal on output 1-4, all the rest will work from any output switched to Normal. Let us know if you have any trouble!
Top |
torontomusician
Post subject: Re: Newbie Girl. Hope I have this right Posted: Mon Nov 30, 2009 1:07 pm |
Hey John, Perfect, thanks very much. Love this pedal and the board and will be using it this weekend. Thanks again very much. Joanne
Top |
Page 1 of 1
[ 3 posts ] |
Who is online |
Users browsing this forum: No registered users and 3 guests |
