Possible to power both DD-20 and DL4 at the same time?
silent bob
Post by silent bob » Wed Nov 18, 2009 10:38 am
Hi, I was wondering if it is possible to power a DD-20 and DL4 at the same time through the courtesy AC outlet. I know it's possible to power through the outlets 5 & 6 but all 8 outlets are taken up. I was thinking about just connecting a surge protector out of the AC outlets and connecting both pedals. Would this be okay to do? Also would this max out the capacity of the AC outlet or would I still be able to add one more pedal down the road? Thanks.
Re: Possible to power both DD-20 and DL4 at the same time?
Post by JohnClark » Wed Nov 18, 2009 11:00 am
The Courtesy Outlet has a stated max of 200 Watts. These two pedals will consume nowhere near that much so it is perfectly safe to run them and others if you need to. Any reasonable amount of wall warts will be well under the 200 Watt max. Good Luck!
