Catalinbread Echorec and PS2+
Bentfinger
Post by Bentfinger » Sat Jun 17, 2017 6:52 pm
specs are 9-18 volts neg tip and 61mA draw. Should I run it from ports 5 or 6 with the switch away from normal? Or any suggestions? Thanks
Re: Catalinbread Echorec and PS2+
Post by JohnClark » Tue Jun 27, 2017 3:00 pm
Sorry for the late reply!
The Echorec will accept 9V-18V so there are a few ways to power it. For 9V operation you would use any output with the corresponding DIP switch set to Normal. For 12V operation you would use any one of outputs 1-4 with the corresponding DIP switch set away from Normal. Output 5 or 6 with the corresponding DIP switch set away from Normal would provide about 14V to this particular pedal.
If you wanted to run the Echorec specifically at 18V you would need a 2.1mm Voltage Doubling Cable or our Voltage Doubler Adapter connected to any two outputs with the corresponding DIP switches set to Normal.
