It is currently Mon Jun 18, 2018 10:15 am
 Post subject: Pedal +2 Modfactor and DL4
PostPosted: Mon May 22, 2017 3:18 am
Hi, I've just got my power plus 2 and am very excited to get it plumbed in!
I'm hoping to power 6 9v compacts (boss, turbo rat, dyna comp etc), my Line 6 DL4 as well an eventide modfactor. Is it possible? Any help would be much appreciated.
 Post subject: Re: Pedal +2 Modfactor and DL4
PostPosted: Mon May 22, 2017 9:33 am
Right On!
The DL4 can be powered from output 5 or 6 with the corresponding DIP switch set away from Normal using one of the cables with the Red end.
The ModFactor can be powered using a Current Doubler Adapter (the one with the Green end) connected to one of output 5 or 6 and any other output with both corresponding DIP switches set to Normal together with another one of the cables with the one Red end. OR it can be powered from its supplied power adapter connected to the Courtesy Outlet on the back of the Pedal Power 2+.
PostPosted: Mon May 22, 2017 11:10 am
Thanks so much for the help, you rule John!
Users browsing this forum: Google [Bot] and 7 guests
