It is currently Wed Jun 20, 2018 5:49 am
Post new topic Reply to topic  [ 13 posts ]  Go to page Previous  1, 2
 Post subject: Re: PP2+ and Nova Delay
PostPosted: Wed Jul 01, 2009 10:16 am
Josh Fiden wrote:
Trueman wrote:
Yes you can use a daisy chain from one of the Isolated Outputs or a Y cable. Also a friend of mine has been powering the Nova from just output 5 (Dip switch ON), giving it 250mA, his works fine too. My advice try both!
You can power from a single output if you use 5 or 6 and make sure the DIP switch is on (away from "normal"). The current demand is a little high, so I wouldn't run another TC Nova pedal in the other output.
Josh Fiden
Founder / CEO
Hi Josh... are you saying that running two TC Nova pedals in 5 & 6 would not work? I would like to run the Nova delay and Nova modulators in 5 & 6. Thanks for any tips you can provide.
PostPosted: Fri Jul 03, 2009 4:06 pm
So... I am running two Nova pedals (delay and mod) out of ports 5 & 6 with the switch away from normal and it seems to work fine.
PostPosted: Mon Sep 28, 2009 1:03 am
Yes, one outlet *can* power the Nova Delay. But it has noticeably more headroom when being powered by two outlets using the t-rex cable. At least that's what my ears find ...
Regards,
Rolf
Josh Fiden
Founder / CEO
