Voodoo Lab
NPN & PNP pedals
http://www.voodoolab.com/forum/viewtopic.php?f=7&t=7542
Author:  bettsaj [ Wed May 03, 2017 7:58 am ]
Post subject:  NPN & PNP pedals
Simple question with hopefully an easy answer.....
I'm going to be using a few pedals in my system (rack based with a GCX) I intend to be using pedals that are negative ground, however i'll probably be using a positive ground germanium fuzz face..... Will this all work on a Voodoo Lab pedal power system as i'm obviously aware of mixing PNP and NPN together on the same power supply isn't possible normally.
Author:  JohnClark [ Wed May 03, 2017 10:49 am ]
Post subject:  Re: NPN & PNP pedals
This is one of the main features of the isolated outputs of a Pedal Power... each output section is effectively an independent power supply. So yes, you can mix positive and negative grounded pedals on a Pedal Power with no fear of anything shorting out.
http://www.phpbb.com/
