Voodoo Lab
Help with Power :)
http://www.voodoolab.com/forum/viewtopic.php?f=7&t=7441
Author:  Twostep376 [ Fri Mar 24, 2017 1:14 pm ]
Post subject:  Help with Power :)
I have three pedals that are going to require some assistance (I don't want to harm. Any of these expensive tools!)
- radial tonebone Pz preamp
- Ehx memory man deluxe 1100-TT
- hamstead soundworks signature tremolo
Can it be done? :)
I have PP2+
Author:  JohnClark [ Fri Mar 24, 2017 2:35 pm ]
Post subject:  Re: Help with Power :)
The Radial PZ-Pre will need to still use its supplied adapter, but you can plug this in using the Courtesy Outlet on the back of the Pedal Power 2+.
The Memory Man Deluxe Memory Man 1100-TT can be powered from output 5 or 6 on a Pedal Power 2+ with the corresponding DIP switch set to Normal.
The Signature Analogue Tremolo can be powered from output 5 or 6 on a Pedal Power 2+ wiht the corresponding DIP switch set away from Normal.
Author:  Twostep376 [ Fri Mar 24, 2017 2:55 pm ]
Thanks! To clarify, the following is from hamstead regarding the trem:
Quote:
You need 300mA for the initial power surge. Although the pedal only needs 180mA to run, it definitely needs 300mA when switching on.
From hamstead website :
Quote:
Power Requirement: 9V to 18V DC 300mA (Centre Negative)
So... The away from normal can supply 300ma?
Author:  JohnClark [ Fri Mar 24, 2017 3:40 pm ]
Not only will the Pedal Power be fine to provide the startup spike, it will goose the Voltage up a bit to around 12V.
http://www.phpbb.com/
