It is currently Sun Feb 25, 2018 2:33 pm
 Post subject: Help with Power :)
PostPosted: Fri Mar 24, 2017 1:14 pm
I have three pedals that are going to require some assistance (I don't want to harm. Any of these expensive tools!)
- radial tonebone Pz preamp
- Ehx memory man deluxe 1100-TT
- hamstead soundworks signature tremolo
Can it be done? :)
I have PP2+
 Post subject: Re: Help with Power :)
PostPosted: Fri Mar 24, 2017 2:35 pm
The Radial PZ-Pre will need to still use its supplied adapter, but you can plug this in using the Courtesy Outlet on the back of the Pedal Power 2+.
The Memory Man Deluxe Memory Man 1100-TT can be powered from output 5 or 6 on a Pedal Power 2+ with the corresponding DIP switch set to Normal.
The Signature Analogue Tremolo can be powered from output 5 or 6 on a Pedal Power 2+ wiht the corresponding DIP switch set away from Normal.
PostPosted: Fri Mar 24, 2017 2:55 pm
Thanks! To clarify, the following is from hamstead regarding the trem:
Quote:
You need 300mA for the initial power surge. Although the pedal only needs 180mA to run, it definitely needs 300mA when switching on.
From hamstead website :
Quote:
Power Requirement: 9V to 18V DC 300mA (Centre Negative)
So... The away from normal can supply 300ma?
PostPosted: Fri Mar 24, 2017 3:40 pm
Not only will the Pedal Power be fine to provide the startup spike, it will goose the Voltage up a bit to around 12V.
Users browsing this forum: No registered users and 6 guests
