Line6 DL4 and Whammy IV with the PP2
franrh81
Post by franrh81 » Sat Mar 18, 2017 12:45 am
I'm trying to power my DL4 on 5 with the dip away from normal with my pp2 and for some reason it won't start. I bought it used and when i tried to turn it on it had nothing connect on it.
Also can I use my pp2 to power my whammy iv?
Re: Line6 DL4 and Whammy IV with the PP2
Post by JohnClark » Tue Mar 21, 2017 10:50 am
On a Pedal Power 2 you should be able to power a DL-4 from output 5 or 6 with the corresponding DIP switch set away from Normal.
Does the DL-4 work when powered from the original power adapter? Has the DL-4 had any of the once popular mods done to it... including changing its power jack?
The Whammy 4 requires AC power and cannot be powered from any of the DC power jacks on the front of the Pedal Power 2. You can power this from the Courtesy Outlet on the back of the Pedal Power 2 using the original power adapter.
