It is currently Fri Feb 23, 2018 9:19 am
 Post subject: Can I use up to 200mA non-Line 6 pedals with a PP2 (not +)?
PostPosted: Fri Mar 17, 2017 6:10 am
I have just bought a used PP2, specifically to upgrade my pedal power and to incorporate a Source Audio Nemesis delay, which requires 200mA.
The Nemesis wasn't operating properly using outputs 5 or 6 (in normal position) and I've now realised that I should/ thought I was getting a PP2+! My mistake.
So my question is- as I don't want to try it without expert opinion- if I select the relevant dIp switch to the up position, will this give me 200 mA from outputs 5 and 6 that I could use with the Nemesis?
 Post subject: Re: Can I use up to 200mA non-Line 6 pedals with a PP2 (not
PostPosted: Fri Mar 17, 2017 1:22 pm
I wouldn't suggest doing that. The voltage might be too high for this pedal in the away from Normal mode.
A Current Doubler Adapter connected to any two outputs with the corresponding DIP switches set to Normal would be the best way to power this pedal from a Pedal Power 2 (not +).
PostPosted: Fri Mar 17, 2017 2:59 pm
Thanks for the response John, that is helpful and saves some potential heartache!
I think I'll actually sell his one in and buy a PP2+,what I originally intended! :)
