Pedal Power output splitter with GCX
Doc
Post by Doc » Tue Mar 07, 2017 8:55 pm
I'm putting 9 pedals in a rack. Planning to power them using the pedal power and have all of them (except one) running through loops on the GCX. If I use the output splitter to power two of the pedals going to the GCX is going to create some kind of issue?
Re: Pedal Power output splitter with GCX
Post by JohnClark » Wed Mar 08, 2017 12:43 pm
This shouldn't be a problem as long as both pedals powered from the Output Splitter are in the same signal path. I'd probably go with two pedals that are routed one into the next just to be sure all is good.
Doc
Post by Doc » Wed Mar 08, 2017 1:23 pm
Just to be clear. I was planning on having both of the pedals routed to separate loops on the GCX. So do you mean they should be in back to back loops? Like loop 7 and 8?
Post by JohnClark » Wed Mar 08, 2017 1:52 pm
Yes... if Loops 7 and 8 were going to be routed in series together.
Doc
Post by Doc » Wed Mar 08, 2017 2:03 pm
Excellent. Can't thank you enough. Just signed up for the forum but have been through many of your posts in the past.
