It is currently Sat Jun 23, 2018 10:34 pm
 Post subject: PP2+ can power
PostPosted: Mon Feb 27, 2017 7:22 am
Hi there,
I am new to power supply and and would like to ask some help or suggestion before getting a PP2+.
I just recently bought a Gurus 1959 Double Decker and would like to know if PP2+ can power it fine?
The power requirements for Gurus is:
9VDC at 230ma or 12VDC at 280ma.
Thanks in advance.
 Post subject: Re: PP2+ can power
PostPosted: Mon Feb 27, 2017 11:57 am
You should be able to use output 5 or 6 with the DIP switch set to Normal for 9v operation.
PostPosted: Tue Feb 28, 2017 3:48 am
Hi, Thanks for the reply. If i flip the dip switch to "On" will that make a 12v output? Also if i use a "Current Doubler" cable for this, Will that make a 12V at 500ma? Can that power up my Gurus at 12V?
Thanks in advance:)
PostPosted: Tue Feb 28, 2017 3:49 am
What I mean is Dip switch On for the 5 and 6 outputs only.
PostPosted: Tue Feb 28, 2017 9:43 am
I would think you could power this from 5 or 6 with the DIP switch away from Normal also, but it is untested so I cannot say for certain that it will be the right way to go. Using a Current Doubler would not be recommended.
The pedal accepts 9v or 12v... do you specifically want to power it at 12v?
