How to connect 2 power 2 plus ?
pascalgr
Post by pascalgr » Mon Jan 23, 2017 11:32 am
Hi
I would like add a second power 2 plus
What is the best solution to connect the two?
There is a special cable ?
Or I must simply use a multiple block ?
Pascal
Re: How to connect 2 power 2 plus ?
Post by JohnClark » Wed Jan 25, 2017 12:27 pm
You can certainly power any model Pedal Power from the Courtesy Outlet on a Pedal Power 2+ (or Mondo).
If you have an Export Model Pedal Power then the Courtesy Outlet is a Reverse IEC and will take an IEC Extension cord to link to a second Pedal Power.
