Noise issue with using of power 4x4 with 4 split adapter
jajc3162
Post by jajc3162 » Sat Jan 21, 2017 10:01 am
As above I have 12 pedals but I use the 4 split adapter so that I can power up all my pedals but I'm having noise issue, my current set up is amp>eventide time factor>jhs alpine reverb>Mxr analog chorus>ep booster>Mxr octave fuzz>mission vm pro>pinnacle distortion>jhs double barrel>sl drive>sp compressor> polytune mini>sc95 wah>guitar.
Basically one of it power the pinnacle and double barrel
The other one power the sl drive and sp compressor
The other one power the polytune mini and sc95 wah
The other one power the vm pro and octave fuzz
3 of it are connected to the high current output
While 1 of it is connected to the 100 ma
The rest are power with one channel
So any advise on this issue?
Re: Noise issue with using of power 4x4 with 4 split adapter
Post by JohnClark » Wed Jan 25, 2017 12:17 pm
I think you will need to break things down a little to find the offending pedals. Try running you guitar thru just the two pedals on the splitter to test if that is the source of the noise.
Also exactly which two pedals are on the 100mA Output?
