Need power supply recommendation for my board.
msmith40
Post by msmith40 » Sat Jan 07, 2017 11:42 am
Hello.........
I've decided to dump my '1 Spot' power supply and join the rest of humanity.
I need a power supply for the following.....
Vox King Wah (1977)
Marshall Guv'Nor (1989-90)
EH Lester G (requires 100mA at 9VDC with a center-negative plug)
Fulltone Deja-Vibe (blue pedal.....run at 18+ volts.)
Foxrox Paradox Flanger (requires 9 Volts, AC (9VAC)
Joyo D-Seed delay (Maximum Current Consumption: 75mA at DC9V)
Is there a Voodoo Lab power supply that can handle all of them?
MUCH THANKS!
Re: Need power supply recommendation for my board.
Post by JohnClark » Wed Jan 11, 2017 1:55 pm
A Pedal Power 2+ would cover these with only the Paradox still using its supplied adapter connected to the Courtesy Outlet.
For 18V you could use our Voltage Doubler Adapter connected to any two outputs with the corresponding DIP switches set to Normal together with one of the included standard Barrel Cables.
The rest of your pedals can each be powered from any of the remaining outputs with the corresponding DIP switches set to Normal.
